buckeye_paul
- Joined
- Sep 6, 2010
- 21
I have a 1970 Johnson 85 HP. Model # 85ESL70B. This will be the third time I have taken the lower unit off and just can't seem to get it right.
On the first two attempts when I used muffs I got flow after the t-stats open. I felt warm water from my tell tale, the ports on the back, and from the bottom vents. The cylinders stayed cool enough to keep my open palm on them. However, when I put it in a tank there was no flow anywhere and the cylinders got hot so I shut it down.
Both times I took it apart I removed all old gasket sealer, cleaned all parts, replaced impeller with a new one, sealed properly, and re-installed. I have a Seloc manual for this type of motor so I'm confident the assembly is correct.
The tubes going up into the upper unit seem to be okay. Can someone explain to me the direction of flow with this system and why there are two tubes exiting the pump housing?
I'm not a nitwit. This problem really has me stumped.
Thanks, Paul
Thanks, Paul
