Water pump parts question
socketholder
Iam working On a 84 35 hp johnson,
I installed a new water pump, however My motor uses a part that goes over the water pump and into the top of it. The manuals I have show that I need an O-ring on the top of my wp but does not name this part.or show the part. Mine was damaged from over heating. what is the name of this part. It acts as a seal on to of wp.
chuck
flabum
Re: Water pump parts question
It is a spacer..... 326692 for standard shaft, 326693 for long shaft. The o-rings are in the water pump kit
F_R
The o-rings are part number 311338...just in case.
socketholder
My part is melted beyond.....lol I put theis Project boat together a couple of years ago My part stood about 2 -2.5 inches high.
My manual shows
Drive shaft "o" ring seals. do I not need the old part that i was using?
socketholder
Sorry, i found it Iwas looking at 9.9 to 15 hp manual. its in my 25-35 thanks for the help.
chuck
flabum
look at your model nuber, if it has a "L" in it, use the long shaft part number, if there is no "L", use the standard shaft part number.
