Water pump question
doehunter
I have a 2001 model 25hp mercury 2 cycle outboard.
I noticed the water pump getting weak, so I took it out and the impeller looked funny. 3 of the fingers went 1 way and the other 3 went the other! Why?
I went to a local Mercury dealer and bought a new pump kit. Well when I opened it the impeller was installed the same way. 3 fingers 1 way and 3 the opposite way! When I questioned it the man tried to tell me that's the way they come! I got him to pull up the exploded view on the microfish and it shows it with all 6 fingers going the same direction as it should.
He seemed a little put off with my questioning it, but finally gave me a fresh impeller instead of the one in the kit.
My question is has anyone seen this before, and should I tell Mercury that someone is shipping them installed wrong? I think after setting on the shelf like that the impeller takes a set and after that might not work right even if you install it right.
Opinions?
Jim
robert graham
Re: Water pump question
The blades of the impeller all go one way. I can't imagine it working correctly like you describe.
doehunter
Yea I know,
What is bothering me is seeig 2 of them. I thought maybe I wasn't the only one.
I got the whole thing back together and now the trim tab is broken! The screw just never got tight!
Might be duck hunting this wekend with no trim tab!
fishing 987
So what direction should the blades be pointing on the impeller? Counter closewise?
