Water Pump rebuild kit
Boilers2000
Happy Spring and start-up season. Quick question, I need to service the impeller on my alpha one Gen 2 / SEI 116 drive. I was looking at kit 47-8M0100526. When I look at the parts it appears to have 2-3 large hole gaskets. However when I look at the service manual and parts diagrams it appears to show the gasket that goes under the faceplate as a small hole gasket. Any issue with using this kit, it quicksilver and says it's for alpha one Gen
Scott06
merc has redesigned the gaskets a couple times it will work for a gen two kit . There should be instructions with the kit to show the gasket orientation.
