Hello, I have a 1994 Evinrude 9.9 HP, model E10ELERB { long shaft } engine and plan on installing a new water pump. After I loosen the bolts for the lower unit, I understand that I have to loosen the 2 bolts that hold the shift shaft in place. First question is, do the end of these bolts simply snug up against the shift shaft, or are there some sort of threads on the shift shaft that I have to catch when reassembling? Problem is I cannot see how it's set up inside. Second question, before I loosen anything up, is it best to have the engine in forward, reverse, or nuetral??
