Water Pump Repair kit
swampboy
I Have a 1966 Gulf Stream with a MerCruiser I Stern Drive Serial # 2028545..MerCruiser Marine Engine Serial # 2045309 Model 120. need a water pump repair kit. I tried Iboats no luck. Where can I get the parts for the outdrive water pump??? Thanks :)
HT32BSX115
Re: Water Pump Repair kit
Howdy,
About 5 years ago I did a complete raw water pump replacement on my 1966 150 Mercruiser #1 drive. I had a problem finding the par too. I finally found the housing etc at a Mercruiser dealer.
There's going to be a point at which it won't be available anymore. At that point you'll probably need to swap out the whole drive with an SEI etc....
Cheers,
Rick
xltier
i have good luck with sierra from napa.
swampboy
Thanks for the info. Since this is all new to me. How do I know what parts I need for the water pump. I was told by the previous owner, that you need to replace the empeller unit. I'm not sure if that is all I need to replace. The boat has been stored for the past 8 years. If I'm going to drop the stern drive I might as well put in all new parts. What is your take on this? I'm making a wooden outdrive stand per instructions I took off the forum and getting set-up for whatever...Thanks....
