Guys,
I've got a 2001 90 HP Johnson (J90PLSIG). I "thought" changing the water pump would be straight forward but I haven't even gotten started. Most (but not all) videos on how to do this state to put the boat in reverse and unscrew the shift shaft screw before taking the lower unit off, one video talked about a cotter pin. However all the videos breeze through this part, some take the entire lower motor cover off but still don't clearly show where this is.
So that's my question where is the screw I'm suppose to unscrew on the shift shaft and how do I get access to it?
The photo below is what I "think" is the shift shaft and screw/pin to remove. This is a picture of the Right side of the motor (if you where looking at it from behind the boat.
