eandkatthebeach
- Joined
- May 27, 2008
- 45
Hello folks - it's been a while since you helped me so I'm back again for more!
I'm trying to change the water pump/impeller on a 2001 Johnson 150, model RJ150VXSIF. I removed the two bolts on each side of the lower unit, removed the trim tab and the bolt that was hidden under it, and also removed the bolt on the tail end of the lower unit.
Problem - I can't get it to separate. I read somewhere that I might have to disconnect the shift rod - somehow?
I have a Clymer manual for the engine - not much help. Can anyone help in letting me know where to go from here??
Thanks again to all that respond
