Water pump replacement questions, first timer
YeahBuoy
Hello all,
I'm going to change the water pump on my omc cobra 2.3L I/O drive and I have a few questions as a beginner
1) do I need to remove the sterndrive or can I change the pump while the sterndrive is still on the boat?
2) should I use any gasket sealers? If so, on what parts and what product do I need?
3) should I use a thread anti-seize lubricant or thread lock on the pump housing bolts?
Thanks in advance, it's much appreciated :)
YeahBuoy
Re: Water pump replacement questions, first timer
The water pump is behind the back cover so you don't need to remove the drive. I always put some grease on the bolts before I reinstalled.
You may want to replace the rubber O-ring and other parts if they are worn.
OMC Stern Drive Upper Gear Housing Parts for 1988 2.3 L 232APRGDE Stern Drive
Thanks for the response. I've seen a YouTube video and that guy spread gasket compound all over the wear plate as well as the o-ring gasket before installation. Is this recommended?
And you put grease on the bolts? Won't this have the opposite effect of thread lock? Is it like puting anti-seize?
Again I appreciate the help :)
bruceb58
I sent you a PM.
