I am replacing the water pump on my 1995 Alpha one gen. two out drive.
The manual shows there being a "water seal" on the input shaft above the water pump. Mine did not have one of these. Should I have one? It did not come with the impeller kit.
Also there is some oil on the out side of the plastic speed sensor housing. Should I be concerned about this? Is this seal easy to change?
Thanks for any help.
