redfury
- Joined
- Jul 16, 2006
- 2,657
Okay, replaced my water pump with a sierra kit from Iboat a couple of weeks ago...had the lower unit off for the winter in the house.
Had a heck of a time getting the copper tube that connects to the engine connected, but I got it done after a second try.
Here's my problem though...when I connect the muffs, I'm barely getting it to pee at all. I worry that I got the vanes bent the wrong direction or that something went wrong with the tube connection. When I was monkeying with the tube, the fiber washer that was on the upper portion seemed to have gotten pulled off when I removed it for the second attempt and got in a little crooked. As far as I could see, it didn't fall out of the leg, and I couldn't see up there well enough to say whether it was wedged up properly when I probed in with a long piece of stiff wire.
Thing is, I'm getting water out from the seam where the lower unit connects to the leg, so I can assume that something isn't right, but I don't know what exactly.
I'm posting this hoping that someone has run across this and has a simple answer for me. I installed the pump according to the manual, so the process should have been solid...I'm either missing something, or I missed doing something the right way ( twisting the housing over the impeller and turning the vanes the wrong direction )...
Help?
Help?
