jjay74
- Joined
- Jul 8, 2007
- 46
Being new to the do-it-yourself world, I have gained a wealth of information on this site. Need to ask another question......Is this where the water inlet on the foot is???
As you may have read in my other posts, I cooked the first water pump impeller by running it in a drum. The water level fell low when the hose came out. Anyway, got a new impeller and have the water pump reinstalled...
I've flushed the motor by putting the water hose against the water tube in the midleg and am getting a strong flow of water through the exhaust holes in the back and through the plug (removed for inspection) in the top of the thermostat housing.
Being extremely cautious, I also hooked the muffs up to the foot with it off the motor. I put them around the horizontal holes in the side of the foot right behind the prop (see pic above). I was thinking that I should be getting water up through the foot into the water pump and out of the hole that mates with the water pickup tube. NO water will come out. Am I correct in thinking this? Is there a way to check for blockage before I put the foot back on? Just want to be really careful this time and cover all my bases. I've got all the time in the world, but not much money to sink into this for careless errors.
