water pump seal
gustaria
Drive serial number 0W581501 Model number 5121200TS MERCRUISER ALPHA 1.47:1 2005
I took gear gear housing apart to check pump impeller as advised. It looks perfect. I was slow and carefull and reffering to the manual at each step. There was no seal on the shaft at the top of the pump housing. I never took the impeller out of the housing just slipped it off and now on over the key. could this be normal. The impeller has seals at it house contact area, but.....
jerryjerry05
Re: water pump seal
Post pics of the parts.There should be a rubber seal at the top of the pump.J
