Water pump seal ?
Canmerc?
Im replacing the impeller on my 96' mercury 150 off shore xl and it seems like theres a seal missing , is there a rubber seal between the plastic sleave and the water pump cover and or the plastic sleave and copper tubing ? neither are present on the outboard or in the kit . any links to pdfs or diagrams would be great , thanks in advance
Faztbullet
Should be a rubber grommet in water pump base to seal around tube...the sleeve is just a guide.
GA_Boater
Welcome aboard.
A picture of the parts Faztbullet is referring to;
Item #40 is the grommet and #13 is the sleeve. The old grommet needs to be pried out, the new one slips in and the sleeve slides into the cover on top of the grommet.
Canmerc?
thanks for picture , i did eventually figure it out all back together - now to test it but in sure its all good
