water pump tube crack
onebadc10
My 1988 135hp mercury ran hot when throttled up but would cool down when i was at idle.it had week pee. I was going to replace the water pump.The impeller looks brand new but i did find this broke plastic tube.Could this be my problem?
what is this tube for?
Tony
onebadc10
Re: water pump tube crack/poppet valves
just in case I have not made myself clear .i am working on both my1988 135s and they have different problems.I am working on the running hot problem now .
I thought I would clean and replace my poppet valves.One engine the housing is tapped and a hose runs to the top of the block.The other engins is not tpped in the housing and has a plug inthe top of the block. Any ideas why?
Tony
rodbolt
there were several designs of the water pressure control based on engine seriel number not year model and even then you will find variations withinn a seriel gouping.
sucks but thats how they did it.
the plastic tube is simply a guide and melted at overheat.
only thing it does is aid in lower unit installation.
