water pump
rocket rich
the water pump on my 9.? hp didn't want to pee yesterday after around 5 minutes I got it to pee... I hope I don't need a water pump already, cause the dealer in mo doesn't answer phone calls. ??? but on the good side I caught a ton of crappie yesterday an today. will try again tomorrow nothing super big all around 11 inches
pvanv
Re: water pump
Often, the issue is debris in the pee tube. To cure that, while the motor is running (in water, of course), slide a stiff wire into the pee tube to dislodge any debris, which will then be pushed out with the water.
ppod
Re: water pump
Years ago I found that there were little bugs that like to make their nest out of mud and other debris in small openings, such as the outlet of the pee tube. Whenever I find no water coming out I clean out the tube and everything works fine. Luckily, that has been my only problem pertaining to cooling water I have ever had on an outboard. Dave
