water pump
rwcreigh1
hello,i just removed my lower unit and removed the pump housing.now how do i remove the impeller.i am afraid to pry because my manual say not to lift the shaft.it does say remove impeller and key.where is the key.1984 johnson 35hp.thanks
medic2051
Re: water pump
I believe, from the last time I replaced mine, the key they refer to is a half moon shaped piece of metal that sits in the shaft. It has a name, I just can't recall. It causes the impellar to spin with the shaft. Should come out without a hassle. I would HIGHLY recommend an OEM manual. Good luck
rwcreigh1
Re: water pump
i have the manual.i dont see a key.is it on top?should i use a little oil?
Paul Moir
Re: water pump
Is the impeller off yet? If it's still on the shaft, it is covering the key. The key is what turns the impeller when the shaft turns, and it does this by sticking out into the slot in the hub of the impeller. <br />The impeller should just pull straight off the driveshaft (right off the end). If it's stuck, a little penetrating oil might help it.
Walker
Re: water pump
If its the half moon tapered key then usually you can get a stuck impellor loose by turning the impellor itself clockwise on the shaft.
Silvertip
Re: water pump
You can't pull the key out separately. It falls out when you remove the impeller. Its very small and fits between the impeller and the shaft.
rwcreigh1
Re: water pump
it been soaking with pen oil but it still wont move up the shaft.any ideas?
reeldutch
Re: water pump
split the impellor.<br />cut it off<br /><br />reeldutch
