Re: water pumps and impellers
If there are two types they must be different in some respect. However, every current outboard has a single rubber impeller built into the lower unit of the motor. Its driven by the drive shaft. When the engine runs, it runs. While size and type varies from manufacturer to manufacturer and by engine HP, they all operate basically the same. If you consider that to be different, then there are a couple hundred types. I/Os on the other hand have two pumps. One like I just described in the lower unit, and one on the engine. Again, they operate in similar fashion but a water pump is a water pump.
