Re: Water separator/fuel filter???
You can get a Racor or Yamaha and spend some money or get the Walmart fuel/water separator for $27, which has worked fine for me. I just unscrew the cartridge, dump it into a clean container to see what was in it, and screw it back on. But I do carry a spare cartridge on the boat just in case. Fresh/clean cartridges are probably more of a critical factor with the high horsepower/high fuel flow rate motors due to a plugged filter restricting fuel flow. My motor is a 90HP and I rarely run wide open throttle, so the flow rate through the filter is fine. The fuel/water separators have got to be the best preventive maintenance item yet. The new Yamaha High Output motors actually have double fuel/water separators on them, one on the transom and the one under the cowl, if that tells you anything about Yamaha's opinion on is on these. Good Luck!
