Re: Water separator general question
There are only two types of filter heads on the market.
One is the "Mercury type", called that because it was OEM for Mercury Marine. The other is what they call the OMC/Evinrude Style, because it was OEM OMC/ Evinrude type.
The Merc head has 11/16"-16 thread and the OMC has a 1"-12 thread. Most filter heads have the 11/16"-16 thread but I would check before ordering.
Can't speak for the other brands but the Racor B32103 fits the merc heads and the Racor B32014 fits the OMC head
FWIW: The filter is the most important parts of the system yet few know the difference between a good and bad filter. Most just assume that as long as they both filter to 10 um they are equal in performance. In reality, that couldn?t be further from the truth.
The pressure drop (flow restriction) thru a filter is critical to the performance of both the filter and the fuel pump. A lower pressure filter keeps the load on the fuel pump at a minimun and will last longer than ones with a higher PD. I have seen filters with pressure drops of 2-3 psi.
You also want to check the water separation efficiencies. Filter efficiencies vary from less than 90% to 99.9% efficient.
The filters I use cost a couple of dollars more per filter, but they have less than a ?-psi drop thru them and they are 99.9% efficient in water removal.
