Re: Water softener salt gurus?
Depending on how high the iron level is in your water, the use of a salt with 'iron out' is not a bad idea. The 'iron out' in no way aids in the removal of iron, it is an acid that aids in cleaning of iron oxide off off the resin beads.<br /><br />Water softeners (sodium ion exchange) effectively remove iron in it's dissolved state (clear water or ferrous iron) by exchanging the dissolved iron ions out of the water stream. Physical filters will have absolutely no effect on dissolved iron.<br /><br />Conversely, iron oxide (rust or ferric iron), being a particle, will not be removed in the ion exchange process and will go right through the lightly packed resin bed. You must use a physical barrier filter to remove iron oxide.<br /><br />Assuming that your water's iron content is 100% dissolved, a small amount of it lingers behind, in the resin bed, after the recharge process and will convert to iron oxide. If this is allowed to occur long enough, the resin bed can become fouled with a substance it was never intended to handle.<br /><br />The 'iron out' simply drives the iron oxide back into a solution which is then flushed out the drain along with the backwashed salt brine.<br /><br />Aren't you glad you asked?<br />
