Water Spots
cbavier
What does everybody use to get the Water Spots off?:(
How do you keep the Water Spots off?:)
My boat after three weeks in the water looks likes speckled bass. ;)
rndn
Re: Water Spots
The black and red Baja I used to own was wiped down every time right after it came out of the water. I used a good wax to also keep the water from setting in one place. With this procees it was easy to keep the boat clean and water spot free.
tashasdaddy
Re: Water Spots
when we are in the keys, and have the boat at the dock, it is washed down every evening, dried and covered. then we have a clean, non sticky boat in the morning.
gcboat
Re: Water Spots
You are dealing with 'hard water' i.e. mineral deposits. Almost a necessity to wipe her down after the bath. Besides, she'll thank you for it in the long run.:D
cbavier
Re: Water Spots
I do wash and wipe it down every time I pull it out. Do I need to use a chamois rather than a towel? Only the painted surfaces shows the water spots.
My boat stays three weeks in the water at a time then the Blue stern, Swim Platform and Freeboard (see Avatar) spots so bad it looks like a speckled bass. I wind up waxing again just to get the water spots off. I just bought some Collinite Insulator wax to try. They say it's the same as Collinite 925. I have been using Meguire's Premium Boat Wax the past three years.
My Boat is a 1986, It Looks New, I'm Fussy,I Intend to stay that way but I do use the Boat a lot . I put 85 hours on the hour meter last year and I probably put 200 on the boat.
ziggy
Re: Water Spots
ducky brand water spot remover.... i've tried many things. this is it....
http://www.duckyproducts.com/water_spot_remover.php
if ya got it bad, a couple apps will still get the job done.....
do keep it waxed though. that helps a lot....boat wax, and wash with boat soap. ucky ducky brand to suit yer needs....
wipe down after the spash is good too..... prolongs the need for ucky ducky brand water spot remover.....
cbavier
Re: Water Spots
Thanks Ziggy I just ordered two 32 oz bottles.
Not a Bad price and free shipping.
Will this remove my wax or just the spots?
ziggy
Re: Water Spots
just the spots, kinda shines it up too..... use as directed.... a damp chamot to mop it up..........i wax my boat fall or spring and once in between usually. other than that, ucky ducky it......
