imported_John o
- Joined
- Aug 24, 2006
- 137
I have a 24' Manitou Osprey pro SHP with a 175 Yamaha on the back.
I get a fine water spray over the bow, kind of a mist with occasioanl larger droplets, when at speed. I'm trying to find why this is happening and how to fix it.
I have a dent in the keel guard on the center tube. (hit the trailer hard when first landing it). Could this be the problem?
Anyone else have one of these and if so do you have the same issue?
The keel guard (for lack of a better moniker) is an aluminum angle welded to the from of the tube and continuing down to the end of the nose cone at least. The dent is about 1.5" high and the guard is pushed about 3/4" to the stbd. The dent is about 4" above the bottom of the tube.
(How would I go about getting the dent removed? Would any aluminum welder be able to pound it out etc?)
But I also get the spray when I'm at top speed (about 38MPH) and I know that the front of the tube is out of the water at that speed. (Somewhere around here I've got a picture)
Any ideas?
Any ideas?
