Hey,
Thanks for looking. I'm just done my winterizing and I must conquer this last obstacle before I am done. I have some water still stuck in my bilge even though I removed the drain plug and used the trailer jack to lift the bow to the highest position possible.
I tried to lift the hull higher using the winch so that the bow eye goes somewhat close to the rollers but the winch doesn't have enough power to push it closer than it is. In the picture the hull is away from the rollers but I have managed to get closer so that both rollers are touching the hull and the bow eye is about 4 inches BELOW the bottom one. Unfortunately this is not enough as water doesn't come out of the bilge. I know that the best practice is to have the bow eye between the bottom roller and the bow stop roller but I just don't see how to do that in my situation as the winch is attached under the bow rollers on the same fixture.
Does anyone have any suggestions to get my hull higher so that the water exits and doesn't cause damage from freezing? I really need to get this done, who knows how much water is under the top floor!
