water temp gauge
irishflies
I just installed a water temp gauge on my 6 cyl. 1998 mecury carburated outboard. I connected the tan sending wire from the overheat alarm sensor on the cylinder head cover.Is this exceptable or do I need to install a seperate sensor on the cylinder cover? There is one bored and threaded hole that is not being used.
gss036
Re: water temp gauge
No, that is not acceptable. The overheat alarm (on the starboard,right head)will only accuate when you reach the level for it to send an alarm signal, I think like 240 degrees. <br />The temp senson/sender unit should be installed in the left side of the head. So you will need a sender and a gauge.
irishflies
There is a overheat alarm on both sides.Why do you think there is a wire from the sensor inside the console? Thanks for the reply.
Coolmaker
Only one of the sensors in the heads is an over heat sensor, the other on is for the temp gauge....
gss036
If you will pull out the one one the right you see that it looks like a snappit toy. When it hits the high temp, the end snaps out causing a circuit to connect to the alarm, when the engine cools back down, it retracts, closing the circuit, thus shutting off the alarm. The other side fits into the hole w/molded sleeve, so you don't read metal temp,it is about 1/2'X 1" and works on temp, the hotter the temp, the higher the reading, it works on a resistance type circuit. I have been messing w/mine as I have either a bad sender or bad gauge, I think it is the sender, just haven't bothered change it yet as I know the overheat alarm works and I have good water flow. In response for your 8:05 post (should not have started a new one) it is a brown wire. If you ground out the wire off the port sensor and have some turn the key on & off quickly, the guage should go all the the way to the right, indicating that you have a complete circuit. It is also a brown wire, trace it up over the top of the engine and it will go into the wire bundle that goes to the dash.
irishflies
Thanks again for the info. I am a new member and apoligize for the mistake. I contacted my merc dealer and he confirmed your reply. He told me that the senser on the port side is factory installed for a future temp gauge. This is the sender that I used.I assumed it was the alarm sensor. He told me the sensor on the starboard head is the alarm sensor.
