mastercylinder63
- Joined
- Jun 13, 2010
- 36
Greetings to all who always helps me and saves me money in expensive repairs. My water temp gauge is showing zero. I took off the sending unit wire and put it to ground. The gauge pinned. I took the old sending unit to the marine parts store and told them to match it up for a 4.3 v6 mercruiser. The unit the parts guy gave me was slightly shorter, but he said it will work fine. I put some pipe tape on the threads and then installed it. I ran the engine for fifteen minutes and the temp gauge still reads zero.
What did I do wrong?? Should I have not used pipe tape on the threads or is it not working because the sending unit is a little shorter, or can it be something else?? Thanks, again !!!
