I have a 86 Mariner 150hp V6. When washing the motor out using muffs the water flow from the outlet is moderate until the thermostat opens up and then water flow increases. The question is after the motor has warmed up and the flow of water has increased how hot should the water be. The water coming from the outlet is hot but not hot enough to burn. Is this normal or not. Thanking you in advance.
