Hey y'all, question,have a 75 Johnson 25 HP, long shaft ,doing conversion to Short shaft,can the water tube be cut to fit or has to be replaced? If it has to be replaced,does the power head need to be removed? Also 68 evinrude 18 HP carburetor slow speed needle is loose even after rebuilding,it will vibrate and move when idling, packing washers replaced,but still not tight as it should be,got me stumped
