Leaving for the shore tomorrow with the boat........Traded my good running 9.9 for this 1992 25hp Mercury just a few days ago. Motor starts on 1st pull. 1st day I took the water pump apart as it was hardly pumping water out the tell tail. Pump is like new so put it all back together. I then checked the thermostat and it frozen closed so I just took it out and put it back together. Tell tail pumps excellent now.
Bought some new NGK plugs(gap @ .040) as the old ones were original! Ran it for a bit and rechecked them. They look like water spots and oily!? The old plugs were nice and dry. Did a compression test and got 120 psi in each cyl.
Only other change was I combined both tanks of fuel into 1(ccame with 2 tank and both had fuel in them). Could it be the other tanks fuel was so old its not firing right?! I mean it idles and runs great even with the plugs being wet.
HELP!!!!
HELP!!!!
