chuck in WA
- Joined
- Aug 3, 2004
- 105
Hello experts,
After owning my 1985 Sea Ray with 140 Merc Alpha MR for 3 years, I decided it's time to have a look at my impeller (for the first time) and install a new one. I did this because of the opinions of many of you on this forum who say it should be changed every year or two, not because I've been having any cooling issues.
When separating the lower unit from the upper gear housing, about a tablespoon of water drained out when the drive shaft splines separated. I can see a few drops of water remaining in the splined female portion in the upper gear housing, which reinforces my opinion of where the water appeared to come from. I assume this is not normal. The o-ring around the top of the drive shaft was intact, so what else stops water from going up into the area where the drive shaft couples with the upper gear housing? When I drained my gear lube, there was no indication of water in the lube, it was green as ever (no milk).
While trying to figure this out, I did some looking over the online MerCruiser manual that Don S always posts, and I have questions on 2 parts. They are numbers 17 and 41 in the diagram attached (or if my diagram doesn't post, it's on page 3B-8 of the Merc manual). I assume #17 is the o-ring that goes around the drive shaft at the top, near the splines? Where does #41 (rubber ring) go? I did not find any such ring when I disassembled the drive and water pump, but one is included in my rebuild kit. Perhaps the lack of this ring allowed water into the spline coupling area? Does this ring simply slide down the driveshaft and rest on top of the water pump?
Thanks all!
Thanks all!
