I'll do my best to be clear. Model 35520 S# 23821<br />I'm getting this old thing running. Bought it used with no promises. Impeller looks and feels fine to me. Soft, pliable, and not really worn looking. In a test tank, it idles, warms up, then stops pumping water. With the plugs removed and the starter turning it, water is restored. I removed the thermostat and same thing. It gets real hot real quick while trying to tune the ide mixture etc. No teltale spray (scavange) after 30-45 second. I crack the seal for the thermostat housing to monitor the waterflow, and I can see it stop after revving a bit, then never return. There is no prop on, and I have only rarely even put it in gear to open the throttle. The impeller key and hub are all intact, and I'm confident the waterpump is assembled properly. With no water the automatic choke never heats up, and so on. The thermostat does work, but I have removed it as a variable, literally. I put a garden hose on the copper tubes from the pump and it appears there are no clogs.<br />Is this a resonable failure mode for an old impeller? I read somewhere that it behaves as a displacement pump at low RPM and then becomes a centrifugal pump at higer RPM to deliver the same volume in each case. The impeller seems fine to me, but clearly I will replace it ASAP and post the results. (Part # would be a help, BTW).<br />Any other ideas ??? What am I missing? The waterflow doesn't slow, it STOPS. I even filled the tank up to the steering bearing just to be sure. <br />Thanks in advance, I'm "DITW" until this resolves. <br /><br />OBTW, how do I get this flywheel off? Custom Puller? Heat? Thanks. Kirby.
