Last year I posted a thread about my boat and finally took it out this week. Engine sounded much better and cooler so I'm assuming I'm within the recommended WOT rpm range. Well since I bought aluminum and I hit something again, I need another propeller. I previously had a 14 x 20 pitch 4 blade propeller and we are planning to buy another 14 x 20 pitch again. Now the question is:
Since I'm buying local and the seller has multiple listing for different sizes, they offer $140 for an aluminum prop and a SS highfive prop. The issue is that the 5 blade prop is 24 pitch and I think that it won't work for my boat while they claim that it is perfect for the boat. What are your thoughts?
If not I can just buy the aluminum 4 blade for $50 and leave the other prop alone.
Some history of the boat: initially bought for $4500. 1800 LSR, 4.3 L Mercruiser Alpha One 18 foot 190 HP. Replaced the 3 blade 21 pitch as the RPMs were too high with a 4 blade 21 pitch.
TL;DR
I go tubing and wake boarding with a heavier load than usual (around 9 adults on the boat).
1. What does adding a blade do in regards to RPM?
2. I know that adding pitch will decrease RPM, therefore if getting a 5 blade prop will add RPMs, should i add pitch as well?
3. Do I need to re-grease the shaft everytime I replace the propeller?
4. I'm planning to replace my 4 blade 20 pitch with a 4 blade 21 pitch, will that be okay for my boat?
5. Should I purchase the 5 blade prop if the pitch is 24?
Thank you.
TL;DR
Thank you.
