Re: Hmmmm, wax coat on hardened resin??? NEED HELP!!!
I have read about epoxy, and like what I have read, but I wanted to use the 3 gals of poly which was pretty much given to me.
Do you know if the BONDO type of resin is waxed? I also have a gallon of that here. I will probably switch to epoxy, because I do not want to have to clean it off before sanding/grinding. It will make for 2 times the work. Maybe I will use it (waxed)to make a livewell, or something.
I am a pretty new poster, on the board. You guys rock!! I have read the threads on here for months, I thought I knew alot! WOW there is still alot I need to learn from this place! I appreciate all the help I have gained from this place!
Time to find some good epoxy now!
