weak cranking power
oddysea1
I have a 1989 200 h.p. Yamaha twin engines the port engine has a weak crank when trying to start and then peters out after 8 seconds or so.I replaced the battery, switched out the starter and starter solenoid from the working engine and still have the same issue.Any suggestions on other possibilities or on a trouble shooting plan would be appreciated.Thank you Andy
99yam40
check all connections from the batteries to the motor including the negative.
even cables can go bad internally.
voltage drop test under a load should show where the high resistance is
tommarvin
Ensign
You should have a battery switch, so you can start each motor with both battery's.
Like the man above, this is a battery cable problem, and it's probably the ground, clean and make sure all grounds are tight with nylon locking nuts.
