Johnson 115hp 1996 J115SXEDR
I've got a weak starter took it apart and cleaned some black dust out, did not test continuity, put some 3in1 oil on the spindle. The bendix has given me problems in the past, I hit it with some liquid wrench to clean it up and then some 3in1 oil. This motor is a pain to work on as there is a timing / flywheel cover that has to be removed, reassembly requires a link/sync. You cannot even see the bendix when it's assembled and cannot crank it with the bendix in place without putting the cover back on. The regulator has been replaced a couple times and it's still giving no tach and shows charging at 16V while running - could that have fried the starter? starter runs fast and quiet with no gears attached.
Battery cable connections cleaned and Tight on both ends, no wingnuts. I'm beginning to think the cables are bad and might be causing the 16v charging or blowing the regulator due to high resistance.
I've got a few Questions:
- How do you tell if the brushes are bad in the starter?
- How do I bypass the solenoid to test the starter?
- Possibly bad battery cables from console to engine. Can I put a short set of car cables on a battery near the engine to test and still use the key to turn it over?
- Will a resitance test using regular ohm scale work to test a battery cable? Should see no resistance correct?
- Can I just have the starter tested at an autoparts store like advanceauto?
