jacksmith2009
- Joined
- Dec 13, 2009
- 6
My 1999 35hp saw salt water for the first time yesterday. Before going out it had quite the strong stream, it did not hit bottom and suck anything up that would damage the impeller, the stream is SIGNIFICANTLY weaker than before.
The motor is not running hot ir over heating. Should I be concerned? Replace impeller for good measure? Is there a NORMAL flow for these engines? How do you measure it?
Anything would be awesome..
Thank you for your time and inputs-----JACK
