bkwapisz
- Joined
- Oct 20, 2009
- 441
Just changed my taillights to LEDS because one didn't work, was completely sealed, and I figured the bulb was bad. Now everything works (as it was) except for that same light when the breaks/signal etc is on. The LED's glow faintly but not enough to see from a distance. Rechecked and replaced grounds, no difference. I have an alternating 12V when the hazards are on but apparently not enough current to fire the light adequately.
My question is this: Having checked everything else on the circuit, would it be most prudent (=easiest) to just replace the run to that light? I have the wire and the boat's off the trailer so now's the time to do it. I'm assuming there's a fault in that wire and frankly it'll take a lot to check the resistance from front to back due to length. BTW it's a 1990 Ranger Trail trailer.
Thanks in advance for any thoughts.
