website to download a johnson 140 service manual??
does anyone know of a website that you can go to to download a service manual?
or does anyone have a breakdown on the Johnson 140 carb (plastic carb) that they can e-mail me
thanks
KYHunter2
Re: website to download a johnson 140 service manual??
As far as a manual , to download. No, such thing. They're under copyright. You can look at e-bay, or Ken cook site.
You may find one cheaper on e-bay.
Sometimes the carb kits, have alittle instruction sheet in them.
If your familiar , with carbs in general, it shouldn't be too difficult for you.
You really do need to get a OEM manual, for your motor.
Or at least a clymer, seloc, etc. Though the information is at times vague, for any specific motor.
As they cover several years, and motors.
Some of the online parts houses , have detailed parts drawings you can look at.
If thats all you need . I believe one is, boatparts.com . Google outboard parts or search here .
The site name, is not coming to mind, if the one I posted isn't it.
KYHunter
looking for a detailed drawing of my carb, as there is a small o-ring included in the kit and cant find where it goes.
thanks
ezeke
Go to the BRP Parts Catalogs by copying the following to your browser without the quotation marks.
"http://epc.brp.com/default.aspx?brands=ej&lang=E"
Then navigate to your motor and select "carburetor".
You can print the diagram and download the parts list to Excel.
KYHunter2
Just so you'll know .
Alot of the kits, are for different motors, and have parts that aren't allways needed .
In each application.
But, its a good idea to check , as you intend.
KYHunter
Walker
thanks
How about on the carb bowl drain plug??
Scaaty
Click this and navigate around for your parts drawings...(skip the stuff at the first screen if it shows up, and go to the catalog). I At the parts catalog, click your motor up at the left and you're on the way to the land of OZ
http://epc.brp.com/default.aspx?brands=ej&lang=e
not on the main drain plug, this is a small black o-ring
does it go on the "tube" that comes up through the middle of the bowl?
ezeke
As Walker said, the only 'O' ring on that carburetor goes on the drain plug on the float bowl as the parts diagram shows.
What was the part number of the kit that you bought?
