i just got a 1969 rude 25hp and thanks to everyone on this forum it now runs like a top after sitting for 25 years. i just picked up a quart of lower unit oil and drained the old and noticed 2 things- 1, the old oil was gray and foamy, i assume from water contamination? 2, i noticed oil coming out of what appears to be a weep hole thats located about 3 inches above the prop on the front? is that correct? it looks to me that the oil i see coming out of the hole is dark in color as in premix exhaust oil? does this mean i need a new prop oil seal and o ring? and is it normal for that weep hole(if it is one) to be leaky? if not, whats the solution?
