Re: Weight Distribution hitch
This is from the Titan Manual. If the chains are long enough(as Dockwrecker appears to have), you can use them.
http://www.rockettrailers.com/pdf/titan model 6 manual.pdf
8. Weight distributing (equalizing) hitches have been an important part of trailering for many years. They shift excess tongue weight from the end of the tow vehicle by distributing it across all vehicle and trailer axles.
Leveling the tow vehicle and the trailer reduces the stress on the suspension components and increases towing stability.
All TITAN surge brake actuators are fully compatible with equalizing hitches. When using weight distributing
hitches with TITAN actuators, observe the following rules:
1) Allow six to eight inches of free chain length,
2) The chains must be vertical (straight up and down) under pulling load, and
3) Tongue weight beyond the specified actuator rating WILL interfere with brake
performance.
The above statement summarizes TITAN's three "rules of thumb" for equalizer/actuator compatibility. Each rule contributes to optimum trailer braking.
RULE #1: Allow six to eight inches of free chain length. This means that the equalizer's chains must be at least six to eight inches long between the spring bars and the hook-up brackets (which attach the chains to the
trailer). Surge brake actuators must be free to compress their internal master cylinder. Shorter lengths of chain will limit the distance the actuator can move, and this restricts the unit's braking.
RULE #2: The chains must be vertical (straight up and down) under pulling load. During towing, these chains must be aligned straight up and down. This should be confirmed on level ground with the trailer coupled (using the equalizing hitch) to the tow vehicle. After checking that the actuator is in its towing position (not compressed), adjust the position of the hook-up brackets on the trailer until the chains are vertical. If the chains are angled forward or back on the TITAN actuator, they have a tendency to either impede the braking action by limiting the distance the actuator can stroke or prematurely apply the brakes by pulling the trailer forward relative to the tow vehicle_.
