Weight of Motor
riden
I have a 94 Evinrude 90 hp V 4
Around what does it weigh?
I plan to do some work to my transom and am curious about plans to deal with the motor.
imported_lorin
Re: Weight of Motor
t's about 290 pounds for the standard shaft, and about 12 pounds more for long shaft.
rickdb1boat
Re: Weight of Motor
An engine hoist works well or a large tree branch and some rigging...
KYHunter2
Re: Weight of Motor
Get it under a tree limb or ceiling joist , etc.
Tie / chain motor over limb, etc.
Witn the front of trailer as low as possible , can jack up rear of trailer slightly , if needed.
Tie/ bind off tightly. Then just raise front of trailer.
There should be enough room to swing motor , out of the way.
I've done this with all the steering and throttle cables still connected.
And was able to use a chainsaw to remove rotten transom, had plenty of room.
KYHunter
