Weird Acceleration
Dandydan
I am having a issue with cool engine response to applied throttle. Engine in my 1994 Sea Sport with a Volvo Penta 290 DP has been running great except when starting out after not running for a couple of hours, ie. after trolling for a few hours with kicker motor. Engine is a 5.0 Ford 302. Fresh rebuild.
When main engine throttle is applied when wanting to take off, the response is non existent. The engine is running, comes up to about 1200-1500 RPM, throttle manipulation does nothing to increase speed, and then it just stays there until it decides to take off and then it jumps up to wherever the throttle position is set. From that point on it is fine. Subsequent take offs from low idle speed is as should be with no issues.
I wonder if there is a electric choke issue or something else. My wife says it just needs to warm up a lot before it decides to go. Not the ideal situation as sometimes there is a need to start up and get moving immediately.
This issue combined with a spun prop (now fixed) made me think I had a problem with a clutch cone. This seems all about carburation. What do you think?
kenny nunez
Has this a problem started started since the engine was rebuilt? Was the carburetor also rebuilt at the same time?
Is your kicker engine a 4 stroke and are you drawing fuel from the same fuel line that feeds the main engine?
Dandydan
This is a new problem that has started since the rebuild. It is another bug to work out along the way. Yes the carburetor was rebuilt by an old guy who is famous in the racing world for his carb work. The fuel to the kicker comes from the same 55 gallon tank but there are 2 factory installed pick-up ports in it. The fuel for the kicker goes to it’s own inline filter before entering the fuel injection system of the kicker motor which has never skipped a beat.
It seems like the last three times out i have had this problem. Someone, (a plumber) suggested that perhaps the throttle cable is gummed up and is not moving the linkage, but is stretching in the cable jacket and the releasing. That is possible but it doesn’t fit the other symptoms very well. Like why would the same thing not occur when the engine warmed up real good.
Thanks for your help.
kenny nunez
Start the engine on a flush out with the flame arrestor removed. The electric choke should start to open as soon as the engine starts and be fully open within 2 minutes. The choke thermostat just might be set too tight or the heating element is either burned out or there is no voltage to the choke housing. Look at the ground wire also.
Dandydan
Thank you. Love low cost repairs. I think i will contact my rebuilder. It was $300.
my guess is it is also the choke, however the choke pull-off should open it. when running with the choke closed, it would be running rich.
reading the plugs would help determine this.
other ideas.....the anti-siphon valve is stuck, and the kicker is pulling fuel back from the main engine. then the motor is struggling with what is left in the bowl until it can re-fill its supply. while its doing this, it would be running lean. again, reading the plugs would help.
or the carb still has issues and should be taken back apart and have all the passages cleaned (and verified clean by probing each passage with fishing line or a fine wire.)
Dandydan
Thanks Scott Danforth. The anti siphon valve was The rebuilders first guess. He was very decent about it and refused to take any money for his hour and a half of tinkering with the carb. He found a little corrosion in the float bowl, and set the jets to where there should be. I had one turned out too far. Other than that he commented that the places were dry that would have indicated anti siphon issues. I haven’t had a chance to get in the water yet. I will update you after that.
kmarine
Just a shot in the dark, possible fuel pump low pressure at idle speed until carb fills up with enough fuel. my first guess was also anti siphon valve, but that was ruled out.
Dandydan
Acceleration weirdness
My 1994 Sea Sport, 19 foot with a 302 Ford is still being weird on Acceleration. I have written on this topic before but maybe have a little more data to describe the issue. I am experiencing a prolonged period of time in which this engine just will not come up to power until it is good and ready and wants too. After it wants to it is fine. Today, the in the water start up went fine. There was a little dying and needing to be restarted a couple times then she settled in and ran fine at about 750-900 RPM. When she warmed up enough to stay running (about 5-7 minutes) we left the dock. At our launch site there is a 5 mph no wake zone for about a mile and then you can open her up. Except that when you throttle up from 12-15K it only goes up to 2000 rpm and just stays there. That is not enough to get up out of the hole so i have learned to back off a bit and just wait. After a couple of minutes of this low speed, without touching the throttle lever, suddenly she just speeds up and I pull the throttle back and off we go running at 3200-4000 RPM and it works just fine. Subsequent stops and starts are not similarly affected until after a prolonged period of cooling while trolling with kicker motor and main engine not running.
I have a 55 gallon tank with two separate factory pick-ups for fuel. The kicker is a 9..9 Tahatsu with its own fuel line and filter and the only common link with the main engine is the full fuel tank. I would suspect some sort of weird siphon phenomenon except the symptoms don’t occur only after use of kicker. Wondering if the accelerator cable is to blame somehow but it seems to operate the carb linkage just fine,
If a motor suddenly pick up speed you would look at ignition issues.-----Run with timing light on each lead and see how spark is behaving.-----Also check / inspect fuel pump diaphragm.----Replace float / float valve in the carburetor.
disconnect and plug the kicker then try it.
Grub54891
Although it may not be an issue, I haven't read where the vent from the fuel tank has been checked for blockage. Unless I missed it. Just something to check.
Dandydan
Thanks for all the in-put. I do have a brand new 2-3 gallon tank that came with the kicker. I have never used it (still in box) so it should be easy enough to try and see if the same thing happens when I only use the kicker hooked up to that little tank and the the other line disconnected and the pick-up plugged off. Otherwise how does a timing light hooked to the 2-8 plug wires help? Am i just looking to see if everything is firing? The vent from fuel tank? Where would that bad boy be? There are the ones that allow air out when dumping gas in, but are there others that allow air in? I’ll be checking for that. It could be fuel pump diaphragm though it is a new pump with the engine rebuild so with as much trouble as it is to get down to the mechanical pump, I’ll save that for later. Could be a faulty float or float valve but I’ll have to have my carburetor expert check that out. No one thought the cable could be the cause so i won’t worry about that for now. I did just remember that the little fuel filter seems to get a lot of stuff pretty quick. Maybe I’ll start with a changing of that. It is easy and I have a spare on board. No gas getting in, boat not gonna go good!
Grub54891
The same vent that let's air out is the same one that let's air in. As far as that little filter getting stuff in it, it means you should clean out the fuel tank. Even up to replacing the fuel lines as they could be deteriorating.
Dandydan
Thanks Grub, Pretty soon everything will be new! Guess I should be getting some hose. Coast Guard approved of course. So I read somewhere that only steel tube is acceptable for fuel pump to carburator. Who is a good bet for bending that tube?
Dandydan
I may have found the issue. Can’t wait to get on the lake tomorrow> I think Jimmbo called it. I will detail the agony when i get back tomorrow>
Dandydan
I was reading a post the other day in this forum that really had my interest. It ended with other readers berating the original author to finish up with what he had started, so I’m back with what is a good ending to my saga so I am not guilty of the same thing. I have figured it out and I do hope it helps someone else.
While we were waiting to get out on the water I went through a few things that I thought were the cause of the issue. The choke would not open so I checked the power to it and there was none. That led to a new alternator and solved that problem. Then I found a ground cable that was broken at the terminal. Replaced that. I was thinking that I was good to go as it was running good on the hose through the muffs I had to duct tape to the outdrive which I learned on this forum. Thanks!
I am not going to go back over the same old ground as all the posts are still up. What I will say is that when we finally got the okay to get out, (Covid) we made it through the no wake zone and applied the throttle. It started to come up and then it just sputtered and died. It wouldn’t restart so very disappointed we came back in on the kicker. My wife said it acts like it is starving for fuel. I wish I would have listened. It would have saved me some time and money. Anyway the book says start with a orderly tune-up, beginning with a compression check. All within tolerance. Broke a plug wire so had to replace those with the new plugs. Also found a lot of crusty stuff in the distributor cap. I felt a little sticking when I spread open the centrifugal advance. It was a bit rusty in there for a newish distributor. That made think I found the problem. Thanks Jimmbo. I cleaned that all up and the timing was perfect.
Finally got through all that and headed to the lake for test run. I let it warm up real good and gave it the gas. Up too about 2000 RPMs it was doing ok then it sputtered and died. Seemed like it was starving for fuel! Back onto the kicker, and over to the edge of the lake where I dropped anchor.
Thankfully, I had a fuel filter on board with me along with the cake pan to catch any drips before it got lost in the bilge. I poured the gas from the filter into a pint canning jar and discovered the contents were about 3/4s water to 1/4 gas. I screwed the new one on feeling a mix of relief at finding an issue and chagrin at having been stumped for so long at such a simple issue. And yes it did solve all the issues I had been having. If I could just get a perfect idle all the time it would be really nice. Another post sometime. The good thing is the other repairs are done and they should last for a while and I have another fuel filter on board in case it starts acting up again. Someone said I should raise up the bow of the boat and stick an evacuator down where the pick-ups are and suck out the lowest point to get any other water out. I may try that if the problem comes back
Grub54891
At this point I'd pull the carb and get it cleaned out, or rebuilt. When you get a bunch of water it does get to the carb, and gunk it up. You'd be surprised how bad they can get. That will also fix the idling problem, the low speed jets are gunk'd up.
