weird johnson
gerke
my johnson 6 hp seahorse from 1965 , ran on one cylinder yesterday , wile running i pulled one of the plugwires and nothing changed .<br />but when i held the wire close to the sparkplug (not making contact with the plug) the sparks jumped over to the sparplug and it started to run on bot cylinders again , then i put the plugwire on and it ran like it should .<br /><br />weird ain't it , what could be causing this problem .
Solittle
Re: weird johnson
Me thinks it be a time to buy some plug wires. If origonal yours are only 37 years old.
JB
Re: weird johnson
Fouled or shorted plug. When you held the wire out from the plug it didn't arc until a higher point on the voltage curve, but at the plug contacts you gave the voltage a very fast rise time. Plug cleaned itself.<br /><br />That very fast rise time is why CDI ignition works so much better than magnetos.<br /><br />I think you need to clean and gap your plugs, or maybe replace them.<br /><br />Good luck. :)
gerke
Re: weird johnson
thanks for your replies<br /><br />i just replaced my sparkplugs a week ago , so i don't think that is the problem .
JB
Re: weird johnson
Gerke.<br /><br />I hate it when people Yeah-But you with info they witheld the first time.<br /><br />New electrical parts, including spark plugs, fail more often than old ones.<br /><br />If the problem comes back, switch the plugs and see if the problem follows the plug.<br /><br />Good luck. :)
gerke
Re: weird johnson
thanks for the info <br /><br />i'm ussing j6c champion plugs .<br />sorry to have yeah butted you jb , but i'm only human , and i didn't know that it whas important information .
gerke
Re: weird johnson
i went to take a good look at my sparkplugs this morning and i noticed the porcelin whas black , does this tell you anything ???
Hooty
Re: weird johnson
If you're talking about the porcelain being black, it means the plug is leaking. Once it gets a nice coat of carbon on the outside, the spark will follow in to ground.<br /><br />c/6<br /><br />Hooty
gerke
Re: weird johnson
hello hooty<br /><br />forgive me for my bad english , but what are you trieing to tell me .
gerke
Re: weird johnson
i put on new wires , i will give it a try this weekend .
gerke
Re: weird johnson
tried the motor this morning , there whas no change ,any ideas ???
Greg Lawrence
Re: weird johnson
clean you plugs, use dielectric grease in the boots, clean your carbs, install a water seperator, check you lower unit oil, replace thermostats
gerke
Re: weird johnson
both plugs are black and everywhere where metal touches my plugwire is black too .<br /><br />but i will check all those things you told me greg .
