once in a while, my chrysler outboard will not start. the starter spins the flywheel, but the motor will not fire. if i run a wire from the positive terminal on the battery to the positive terminal on the coil, there is a small spark and then the motor will fire right up as soon as you touch the key. 95% of the time, this is never a problem. but occasonally this happens and the only way to get the engine to fire is to run that wire. any ideas about what to do?
