Weird starting issue: Usually it turns over and starts but not always...
Twhjelmgren28
I have a 120hp Mercruiser i/o. I kept both batteries (deep cycle and starting batter) on a trickle charge throughout winter. I should mention that I also installed an ACR and a dual circuit battery switch last summer.
For some reason, sometimes my boat will turn over and run just fine and other times, when I turn the key I get absolutely nothing; no sound, no click - the only thing is my gauges set themselves, which makes sense.
For example: I could start it five times in a row and then the sixth and seventh time nothing happens when I turn the key. On the eighth try it will turnover and start.
I plan on cleaning all the connections at the ignition switch and the starter tonight after work. My battery connections are very clean and tight already - also, the ACR shows that both batteries are combined when they are over 12.6v so I'm certain the battery has enough juice (also nothing changes when I switch to combine both batteries). The only other thing I've noticed is sometimes after I turn the ignition switch, it kind of gets gummed up at the "start" spot and I almost have to help it back to the "on" spot.
My thoughts are:
1. Bad/corroded connection
2. Bad starter
3. Bad ignition switch
Any other suggestions for what I should look into are greatly appreciated - for now, I'll just work on cleaning those connections.
Thanks!
Sounds like a bad switch to me, and even if that isn't the issue I would replace it
My thoughts are:
2. Bad starter
Ayuh,..... I'd start at #1, 'n go to #3,..... 2 is possible, but #1 is 'bout maintenance,....
A test light will help with testin' the switch,....
kmarine
Is the solenoid clicking are the connections clean with a good ground. I replace lots of these for people. About 1/3 of the starters replaced have only solenoid issues.
I would go with a bad connection, or a bad pilot relay
Twhjelmgren28
I appreciate all the responses. Thanks!
I guess I will start with #1 (maintenance/cheapest) and for sure replace the ignition switch, as AllDodge stated - it is getting kind of getting gummed up, as I mentioned.
Then, I'll start looking into starter and/or pilot relay as mentioned.
I will be cleaning all connections...The solenoid is NOT clicking when I turn the key. There is absolutely no sound whatsoever...
Thanks again and I'll keep you posted.
