Re: Weird Starting problem
Keep in mind that pulling the kill switch does not stop the motor from turning over. It only kills the ignition so the motor will stop if its running. Its hooked to the ignition circuit, not the starter circuit.<br /><br />Its most likely, as mentioned above, the starter solenoid. <br /><br />Good luck!
