1965 Starcraft Holiday, Merc 110 4cyl inline.
The deck on this boat was replaced in 2004. I do not know if engine moust were replaced.
Before the season ended I started getting a vibration that rattled everything in side tackle lockers and the forward hatch even rattled.
This only happened at about 5 mph as read on a gps. Not above or below around 5mph. Boat runs fine no miss or other problems, and will even hit 30 mph gps if I have to get back in fast. Normally only run about 2/3 throttle max. Timing checks OK. Mechanical advance on the distributor seems to work. It advances the timing mark as I accelerate. ( on the water test)
I am thinking, gimbal bearing, U-joint, Engine Coupler, or Engine Mount.
I am going to pull the stern drive later and work on the problem this winter.
Any Ideas on what failure would normally cause this boat shake?
