Welding
Turin
Is it Posible to weld on a evinrude outboard, because my enginge fell from its stand :eek: and the little O Shaped thing thad holds the trotle broke off.
I would trie to weld it back on or should I invent something difirent
nymack66
Re: Welding
Absolutely, mine broke off during the removal and I took it to a machine shop and they welded it.
Turin
Re: Welding
I decided to try something different first.
I used a big rvs O ring and the best epoxy glue i could find.
I glued the ring shaped thing back on an put the O ring on top of it it has the same size I will put another O shaped ring on the other side to i hope this will be stronger than welding.
If it doesn't work I will take it to a professional welder I'm afraid ill mess it up (I'm not the best welder there is)
