hd883chopper
- Joined
- Sep 14, 2010
- 41
Hey everyone,
I have a 30amp WM portable Smart Charger w/ float capabilities. I was wondering if any of you have this charger or are familiar with it.
I just started using it on my 2 starter bats and 2 deep cyc bats it seems to work well except it never seems to get to the "Float" mode. Regardless of what setting (2,10 or 30a) I use, it seems to push up to about 14.5 to 15volts to the bat, then seems to settle down and hover around 13.5 volts. The meter that registers amps pulled says "FULL" so I'm assuming at this point the charger is just pushing a continuous 13.5 volts and the battery is at full charge.
My question is....When does it go into float mode? I thought that was the main reason to buy one of these fancy little dudes? Maybe I'm missing something...Can anyone clear this up for me?
I even called WM support and the tech told me that he thinks the charger has to get up to 14 or 15 volts before going to float. He didn't seem very sure of his answers though. The only thing is that I have seen the voltage surge up there, but then it just settles down to 13.5.
http://www.westmarine.com/webapp/wcs/stores/servlet/Product_11151_10001_102155_-1?cid=chanintel_google&ci_src=14110944&ci_sku=102155
Thanks a bunch for any help in clearing this up.
HD.
HD.
