Re: West System fiberglass repair - What does NOT stick to it?
I've done a fair bit of glass work. What I prefer to use is first a paste wax, and I like to put on two coats, followed with Poly Vinyl Acetate (PVA) brushed on. In addition to the mold release agents, you need to make sure you have sufficient draft, and smooth surfaces. It is possible to have items that aren't adhered by the glass, but are physically locked in place, hence the need for draft and smooth surfaces. <br /><br />Whatever extra time is needed to plan and execute a good release is well worth the effort, as one stuck piece will permanently give you a bad disposition
<br /><br />Plugs for molds can be made from most anything, wood, foam, dry wall mud, bondo, etc, etc. Just make sure the materials are comapable, bondo and poly resins will melt most foams.
